Hey Guys!,
Not sure how many know this (being new to the group and all) but I design and sell custom R/C electronics...
The main products I sell are R/C controlled Navigation Lights for R/C models... I sell two different LED controllers, along with accessories such as LEDs, wire, lens, etc... basically everything you'll need to add some real scale-looking lights to your R/C model. 90% of my orders are amazingly overseas... these folks are REALLY into gadgets if you already do not know. Most of my customers use these controllers on R/C Helicopters, and most customers participate in big scale meets in Europe. My webpage is at http://www.diyrc.com, while my webstore is at http://shop.diyrc.com
Two gadgets I sell are the Mini-Flash and Mini-Beacon LED Controllers. They both are controlled (on/off) using a spare receiver channel and either a knob, switch, slider, etc... on your transmitter. The Mini-Flash is a 4-channel, PC-programmable LED sequencer... allowing you to program almost any imaginable flash pattern, while also allowing you to control (on/off) either of the 4 channels using your R/C gear. The Mini-Beacon is a single output controller that mimics a rotating strobe beacon (like that of a lighthouse)... and the user can choose 1 of 12 possible patterns using a simple jumper on the control board. The links below should bring you to the two controllers:
CLICK HERE FOR MORE MINI-FLASH LED CONTROLLER INFO
CLICK HERE FOR MORE MINI-BEACON LED CONTROLLER INFO
If you also happen to have an interesting R/C electronic gadget idea, or simply need help with soldering, wiring, etc... please let me know, I'll see what I can do to help.
R/C Nav Lights and LED Controllers...
Re: R/C Nav Lights and LED Controllers...
Hi Tom,
Can you convert an old Kraft single stick radio to spektrum 2.4? Didn't you use to repair Kraft radios at one time. I have a series 74 that's in pretty good shape with batteries that hold charge. Let me know if you can and what the cost would be.
Thanks, Ted
Thanks, Ted
Users browsing this forum: No registered users and 27 guests
