X650 Quadcopter - RCTimer.com
Multi-Copter Projects - as if one spinning blade wasn't enough fun
Re: X650 Quadcopter - RCTimer.com
Very nice setup you have there. Way more than an entry level copter. everything seems to work well. The GPS and camera stabilization is the best features I like. I am at the budget entry level stuff. It will be fine for what I want to do.I think a HD KeyFob camera is all I want to use on my Quad. Happy flights.
HitNRun
Post by HitNRun »
THIS!!! Genius!!!!! :o
admin wrote:"This ArduFlyer flight control board also includes a GPS unit and 2-way telemetry system which allows you on the ground to view all flight parameters on your PC-based ground system, while also allowing you to control the quad while it's in flight. The ground control software allows you to use google maps to plot a flight plan using an interface like google earth, and the ArduFlyer allows you to download waypoints to it, allowing the quad to autonomously perform flights, including auto take-offs and landings... now how cool it that!" 8-)
That is beyond awesome, on so many levels!
You can map out a route and basically auto pilot it through the "course" you've made via waypoints?
Amazing!!
I want it !!!!!!!!
It WILL be mine! :D
Users browsing this forum: No registered users and 18 guests
