Nutball- A Round 12 & 17" Pizza Plane Indoor-Outdoor
Posted: Fri Nov 14, 2014 9:22 am
This is an easy build using any type of foam you have access too. But there are weight penalties if you do not use the preferred foam and glues.I think indoor in smaller sizes under 12" you want 1mm or 2mm Depron available online Search. Another option is the Take Out boxes for outer wing, elevator, and rudder foam. Use 2mm for the center fuselage. It goes together fast and if you have all the ingredients already on the bench it can be put together in as little as 2 days. . It flies very slow if the weight is down.
I use my printer after I size the plan to the diameter that I would like to try. Then I print the plan as a tiled sheet on standard paper. Match the lines and glue the plan together. The thinner foam may need a small carbon fiber spar in it to stiffen the frame. You can use the plan rudder or do as I chose and just draw out a fuselage for side view. The perimeter of the disk should have the thinnest piano wire available for bang protection. Use DuBro Blenderm tape(hinge tape) for the rudder & elevator. Buy or make foam wheels for lightness and a stiff wire landing gear. Tri all the micro servos out and go fly.
The thread is here and it is large. The best way to see it is click a picture and then click Pictures in Thread.
http://www.rcgroups.com/forums/showthread.php?t=836389
Free Plan Here:
http://www.rcgroups.com/forums/showpost ... stcount=16
YouTube
https://www.youtube.com/watch?v=5tRyLPr ... r1vNKSmRqQ
Vimeo
https://vimeo.com/111813821
Free Plan Here:
YouTube
Vimeo
