GWS P-38 Lightning ARF. This plane was extensively strengthened with carbon fiber rods and arrow shafts. The adequate motors are fly it just about scale speed with no reserve power. After hanging around a couple years I decided it should be flown. The battery is 2200mah 11.1v 30C lipoly. Maybe later a couple more powerful motors will go nice.
http://www.youtube.com/watch?v=A8DuGxX8 ... e=youtu.be
9-2-2012 GWS P-38 Lightning
Re: 9-2-2012 GWS P-38 Lightning
This is a update from spring 2014.
May 24th 2014. This is set # 02 on a motor upgrade. They fly good and sound nice on 3s lipos
https://www.youtube.com/watch?v=N62detLx4s0
June 6th 2014. This is set #03 motor swap. These are fast performers.
https://www.youtube.com/watch?v=TVy0EaSkJGk
Re: 5-20-2015 GWS P-38 Lightning _ Molding Parts link
Here are further build links from the early build.
Another note on the GWS plastics. You can use them as molds to make Epoxy glass/cloth copies. I did the cowls and nose while I had the originals with P&P. You can do it using the inside of the original plastic also. So much stronger. If you smash the stock ones you will be hard pressed to get new ones. You can do this with almost any kit plastic Vacuformed parts. Worth the extra effort.
Here are links for info
Cowls using P&P mold.
http://www.rcgroups.com/forums/showthre ... ost7077471
Next
http://www.rcgroups.com/forums/showthre ... ost7314647
Next
http://www.rcgroups.com/forums/showpost ... tcount=731
Good luck,
Next
Next
Good luck,
GWS-38: The Aviation Legend
http://www.rcgroups.com/forums/showthre ... st31814797
And here on pages 75 & 76. GWS P-38 Build questions.
http://www.rcgroups.com/forums/showthre ... 60&page=76
Users browsing this forum: No registered users and 21 guests
