Re: MEETING MINUTES! (Last Updated: 9/28/2020)
This list captures all club meeting minutes since December 2011, when this webpage was started (most recent minutes are on bottom)
Simply click on the minutes file you want to review (you'll need Adobe to read the PDF files)... Enjoy![/size]
Note: In December we had the Northeast Terminal closed due to earlier bad weather. If it happens again during the winter months in the future, please visit the Airport Grill building and we will hold the meeting in the waiting room.
The September meeting was held at our club flying field in South Dartmouth, MA for the summer months . It works out better with the Cov19 distances apart. We will move back indoors later into the cooler fall season when announced beforehand..
Please read the new ByLaws Updates in the August issue. We also added an occasional evening flight at sunset into dark. Contact Pres. Gary, Bob Pacheco, if you want a last minute on the same day notice for the later day flight. I would say about 6:15Pm to about 7:45Pm finish. We are using email at this time for a notice. Maybe 1 or 2 more times as the sunsets are getting earlier
Minutes 5-1-12.pdf
(24.62 KiB) Downloaded 300 times
Minutes 6-5-12.pdf
(21.94 KiB) Downloaded 292 times
Minutes 7-10-12.pdf
(23.63 KiB) Downloaded 309 times
Minutes 8-7-12.pdf
(22.08 KiB) Downloaded 300 times
Minutes 9-4-12.pdf
(18.28 KiB) Downloaded 280 times
Minutes 10-2-12.pdf
(20.92 KiB) Downloaded 281 times
Minutes 11-7-12.pdf
(23.5 KiB) Downloaded 316 times
Minutes 12-4-12.pdf
(19.96 KiB) Downloaded 273 times
Minutes 1-2-13.pdf
(24.72 KiB) Downloaded 275 times
Minutes 2-6-13.pdf
(15.67 KiB) Downloaded 327 times
Minutes 3-5-13.pdf
(15.83 KiB) Downloaded 328 times
Minutes 5-7-13.pdf
(10.38 KiB) Downloaded 316 times
Minutes 6-5-13.pdf
(11.49 KiB) Downloaded 331 times
Minutes 7-2-13.pdf
(21.99 KiB) Downloaded 279 times
Minutes 8-6-13.pdf
(11.67 KiB) Downloaded 290 times
Minutes 9-3-13.pdf
(103.58 KiB) Downloaded 304 times
Minutes 10-1-13.pdf
(24.81 KiB) Downloaded 281 times
Minutes 11-12-13.pdf
(27.37 KiB) Downloaded 303 times
Minutes 12-3-13.pdf
(10.93 KiB) Downloaded 299 times
Minutes 1-7-14.pdf
(26.15 KiB) Downloaded 306 times
Minutes 2-4-14.pdf
(20.68 KiB) Downloaded 330 times
minutes 3-4-14.pdf
(28.39 KiB) Downloaded 326 times
Minutes 4-1-14.pdf
(23.61 KiB) Downloaded 313 times
Minutes 5-6-14.pdf
(27.26 KiB) Downloaded 295 times
Minutes 6-3-14.pdf
(25.63 KiB) Downloaded 298 times
Minutes 7-1-14.pdf
(113.2 KiB) Downloaded 305 times
Minutes 8-5-14-part2.pdf
(400.74 KiB) Downloaded 314 times
Minutes 8-5-14-part1.pdf
(399.62 KiB) Downloaded 295 times
Minutes 9-2-14.pdf
(118.78 KiB) Downloaded 315 times
Minutes 10-7-14.pdf
(134.75 KiB) Downloaded 305 times
minutes11-4-14.pdf
(142.93 KiB) Downloaded 295 times
minutes12-2-14.pdf
(127.62 KiB) Downloaded 295 times
minutes1-6-15.pdf
(117.3 KiB) Downloaded 308 times
Minutes 2-3-15.pdf
(222.71 KiB) Downloaded 323 times
minutes3-3-15.pdf
(103.99 KiB) Downloaded 308 times
Minutes 4-14-15.pdf
(117.32 KiB) Downloaded 298 times
minutes 5-5-15.pdf
(115.79 KiB) Downloaded 304 times
minutes 6-2-15.pdf
(126.68 KiB) Downloaded 315 times
minutes7-14-15.pdf
(127.21 KiB) Downloaded 286 times
minutes 8-4-15.pdf
(121.57 KiB) Downloaded 280 times
Minutes 9-1-15.pdf
(115.2 KiB) Downloaded 291 times
minutes 10-06-15.pdf
(157.55 KiB) Downloaded 267 times
Minutes 11-3-15.pdf
(175.1 KiB) Downloaded 262 times
Minutes 12-1-15.pdf
(141.65 KiB) Downloaded 288 times
Minutes 1-5-16.pdf
(123.17 KiB) Downloaded 321 times
Minutes 2-2-16.pdf
(117.18 KiB) Downloaded 274 times
Minutes 3-1-16.pdf
(117.59 KiB) Downloaded 277 times
Minutes 4-6-16.pdf
(183.45 KiB) Downloaded 279 times
Minutes 5-4-16.pdf
(128.27 KiB) Downloaded 295 times
Minutes 6-7-16.pdf
(127.26 KiB) Downloaded 264 times
Minutes 7-5-16.pdf
(119.34 KiB) Downloaded 294 times
Minutes 8-2-16.pdf
(138.8 KiB) Downloaded 275 times
Minutes 9-5-16.pdf
(116.94 KiB) Downloaded 270 times
Minutes 10-4-16.pdf
(134.89 KiB) Downloaded 282 times
Minutes 11-01-16.pdf
(123.75 KiB) Downloaded 263 times
minutes 12-8-16.pdf
(120.94 KiB) Downloaded 255 times
Minutes 1-3-17.doc
(34.5 KiB) Downloaded 247 times
Minutes 2-8-17.doc
(33.5 KiB) Downloaded 293 times
Minutes 3-7-17.doc
(33 KiB) Downloaded 246 times
Minutes 4-4-17.doc
(33.5 KiB) Downloaded 239 times
Minutes 5-3-17.doc
(33.5 KiB) Downloaded 254 times
Minutes 6-6-17.doc
(35 KiB) Downloaded 264 times
Minutes 7-8-17.doc
(33 KiB) Downloaded 247 times
Minutes 8-1-17.doc
(35.5 KiB) Downloaded 239 times
Minutes 9-13-17.doc
(33 KiB) Downloaded 277 times
Minutes 10-3-17.doc
(34 KiB) Downloaded 245 times
Minutes 7-2-2019.pdf
(218.06 KiB) Downloaded 269 times
Minutes 4-2-19.doc
(35 KiB) Downloaded 253 times
Minutes 8-6-13.pdf
(11.67 KiB) Downloaded 297 times
Minutes 8-7-19.doc
(39 KiB) Downloaded 248 times
Minutes 9-3-2019.doc
(37.5 KiB) Downloaded 243 times
Minutes 10-1-2019.doc
(15 KiB) Downloaded 219 times
Minutes11-5-2019.doc
(36.5 KiB) Downloaded 258 times
Minutes 12-3-2019.doc
(37 KiB) Downloaded 262 times
Minutes 1-7-2020.doc
(39 KiB) Downloaded 244 times
Minutes 2-5-2020.doc
(39 KiB) Downloaded 281 times
Minutes 3-5-2020.doc
(39.5 KiB) Downloaded 240 times
By-laws Rules and Reg - amended 8-22-2020.doc
(73.5 KiB) Downloaded 268 times
Minutes 9-26-2020.doc
(39.5 KiB) Downloaded 292 times
