101" SU-26 Sukhoi - 100cc Electric Conversion
Posted: Fri Jan 20, 2012 10:57 am
Well... I splurged for a large scale (101" wingspan) 100cc SU-26 Sukhoi ARF... relatively cheap for its size, which had me a bit concerned, but upon delivery... it's an awesome, well-built airplane! Originally designed for a 100cc gasser... I plan to convert to electric... my biggest yet!
Nitroplanes had them on sale all winter... could not resist for the price!
http://www.nitroplanes.com/su26100cc101.html
I plan to use a 100cc brushless motor from Hobby King.
http://www.hobbyking.com/hobbyking/stor ... duct=14427
A good friend of mine from France purchased this motor for a large scale Carden ARF he converted to electric (he originally had a DA100 in it and suffered a broke crank shaft) and said it packs quite a punch, and for the price you can not go wrong (something comparable like a large 100cc Hacker will cost around $1,200). Can't wait to get going on this project (maybe this weekend). I'm going to get a CF wing tube for it though since the aluminum one they provided appears fairly heavy for my liking (HK upgraded the tube from a 25mm to a 38mm tube, since some customers were experiencing failure of the original 28mm thin-walled tube).
I plan to use four (4) 5800maH 6s packs in a 12s2p configuration (11,600maH, 12s), along with a Castle Creations HV160 ESC and probably a 3-bladed Mejzlik 30" CF prop. It's a monster (will barely fit in my minivan) but should float like a kite. The expected weight should be around 28-30 pounds (my 89" A6M5 Zero weighs 28 lbs so this should be a joy to fly). I'll try to post some pics and updates as they occur... hopefully sooner than later!
