FAA Proposes Flight Remote ID-Comments End March 2nd
Discussion around the FAA Announcement of the Small UAS Registration Rule
Re: FAA Proposes Flight Remote ID - Preloaded Comment for FAA
This link will gives you an AMA drawn up comment that you can use to send to the Federal Register. Left click mouse and swipe to copy it. Then go to the below link and Paste it in with a right click. You can also add or use your own comments if you wish,. Be civil with your comments please.
http://amablog.modelaircraft.org/amagov ... remote-id/
Comment Form. Copy and Paste above AMA pre -composed comment into this link. A green Comment box upper right will generate the Comment Submit page to place your comments or the ready made one or your own composed comment to the FAA committee for reviews. There is 56 days before a final decision,
Thanks,
https://www.federalregister.gov/documen ... en-comment
Re: FAA Proposes Flight Remote ID and Further 400ft Rules 2020
Your comments to the FAA are getting closer to the closing date. Your help is needed to.make a comment with your thoughts on the new proposed FAA ruling Remote ID Transmitters.
Visit HERE:
https://contentsharing.net/actions/emai ... iFLGN5Aivx
LAST CHANCE TO SAVE THE HOBBY
We Need 25,000-plus AMA Member Comments
Posted at FAA Before March 2, 2020
FAA Proposed Remote ID Rules
Necessary for Some and Unacceptable for Others
NPRM COMMENTS & INSTRUCTIONS
Thank you in advance for submitting a comment. We sincerely appreciate your hard work and support.
Best Regards,
Andy Argenio
AMA DI VP
Cell 401-575-6215
brandshobby@gmail.com
jerryn
Re: FAA Proposes Flight Remote ID-Comments End March 2nd
Post by jerryn »
In my comment I reminded the FAA they already have a tool to help assure safety, it's called LAANC. I also recommended permanently adding all AMA registered airfields to LAANC. I also informed them that many hobbyist, including myself fly light weight airplanes under 2lbs that do not have enough lift and flight battery to carry a micro transponder.
