What's on your bench??
Great Planes ARF Extra 300s that I aquired from my dad.Neighbor passed on and had hanging from ceiling.Saito FA-80 four stroke was removed,fixed and bench run.Any thing that could be unbolted,removed was and replaced.New Spektrum reciever and fixing the cracks in the cowl is what I have left to do aside from the programing.Plane is solid,look foward to flying it .
D.M.L.
Gee, what don't I have on the bench!LOL Still working on a Ziroli designed P47 and when the Skyraider comes out of the paint shop, I'll be working on it. That will need the radio gear, engine, fuel tank, and all workings installed including the custom made electric rotating gear. It's a kit from the 70's with an old school Enya 46c
Awesome Ted!... love the electric retracts.
Actually, I designed a set a few years back for my 1/4 scale A6M5 Zero... I basically modified a set of Robart retracts such to use a custom jackscrew mechanism... worked excellent until a landed a bit too hard one day and pushed both retracts up through the wing... Ug...
I started a new post about those retracts here:
viewtopic.php?f=5&t=35
Tom, I sent you a PM on your actuators. Don, this is an old Kyosho kit which I think was probably made by Maratuka. That is the same company who made the Royal line of warbird kits which also had the nice spun aluminum cowls. Right now Gerry has it and it's going to get an old school paint job as it is an old school kit with an old school power plant. It should really be different. Hope it flies well. Maiden is scheduled for next spring.
Also working on my VQ P39 Aircobra. This bird flies great but not retracts or provisions for them. I am changing that and it should be ready to go soon. Nose gear is in and slick as Sh@T! Just got to put the two mains in the wing and it will be done. Gear legs are real short and the tires will just clear the retract motor bodies. Pictures coming soon.
Nice Ted!...
That's going to look great in the air with the retracts up...
Happy New Year btw!
Happy New Year btw!
Wow Ted, nice job on the retracts. Plane looks slick with them up.
D.M.L.
Gerry and I went to the field today and flew the Aircobra and my VQ Zero. Both have Saito 65's turning 13x6's and both have HK electric retracts. Man, the P39 really looks good now and really moves out with the gear up. The retracts worked perfect and this thing lands like a dream. Will have to move the nose wheel steering pushrod in on the servo wheel as I've got too much steering. Will do a 3' circle on the ground!
What a nice day at the field today. Hard to believe it was Dec. 30th!
Skyraider
Some of Gerry's magic! Getting closer to the finish line!More painting, decals, wing walks, panel lines, etc. Then it's putting the retracts, radio gear, engine, and fuel system. Gluing up the control surfaces and balancing. Maiden is on the horizon.
Users browsing this forum: No registered users and 16 guests
